TwinTurbo.NET: Nissan 300ZX forum - Looks stock with the paint dot.
Joe@ZSpeed (Spddracer)
on April 09, 2011 at 4:10 PM
injector resistance test
posted by boostlv
on April 09, 2011 at 03:19 PM
370CC twin turbo injectors (old style)
www.Zspeedperformance.com
boostlv
15:19:47 04/09/11
Looks stock with the paint dot. -
16:10:44 04/09/11
Strongly recommend switching to new-style injectors. (n/m)
Under_Powered
16:49:51 04/09/11
most likely stock with the stock injector caps and brownish
5280Z_nightstalker
18:26:48 04/09/11
I'd grab Bernie's kit outta the classys unless goin bigger
CoHPhasor
19:03:26 04/09/11
So going bigger will require ecu upgrade, will I gain
boostlv
21:18:43 04/09/11
Yes, if you raise the boost, which most ECU upgrades include
Under_Powered
21:28:58 04/09/11
I know that stock turbos should stick to 15psi tops
boostlv
22:35:22 04/09/11
If you are replacing all 6, you should go to 740's.
zellamay
20:37:14 04/10/11
Please sign in the poll if you've not done so already
Zarcasm(Hfd, CT)
11:54:53 04/10/11
